It is currently Wed Aug 27, 2014 3:42 pm
 Post subject: Double Encryption possible but is it more secure ?
PostPosted: Wed Apr 24, 2013 10:47 pm
Hi,
I just tried encrypting a Partition twice using two methods & it did so with no problem but is it really more secure ?
I used "Folder Lock" software to create a container & put the entire partition data in it.
Then I encrypted that partition using Windows BitLocker with a different password & it it all went smooth.
Then I tried to decrypt both of them to make sure that I do get all my data back & I did.
Thus this was a case of encrypting an encrypted container which made me think, is it more secure if I used two different password for each encryption ?
Need opinions please.
Thanks
 Post subject: Re: Double Encryption possible but is it more secure ?
PostPosted: Thu Apr 25, 2013 6:00 am
Sure, but once you decrypt it, it's still as vulnerable as anything to a side channel attack or whatnot.
